Activity Forums Adobe After Effects Remap time without affecting “Time Displacement”-Effect. Is this possible?
  • Remap time without affecting “Time Displacement”-Effect. Is this possible?
    Posted by Andra on April 6, 2007 at 2:13 pm
    Hi everyone!
    I’m kind of trying to combine two tutorials Aharon did a while back. I want to make an animation of a nice sinus shaped waveform, but still have it follow certain curves.
    What I’ve come up with so far, is this:
    I’m using AE 6.5 on an Intel MacBook Pro.
    All comps are 4 secs at 25 fps
    Comp 1:
    Solid with a line-shape.
    Line shape gets Stroked.
    Stroke gets Wave Warped with the Wave Height being animated from 0 to 35 over 4 secs.
    Wave width = 6.
    Comp 2:
    Solid with Fractal Noise.
    Fractal Noise has complexity of 1, and is stretched vertically.
    No animation yet, but I plan to animate the anchor-point horizontally.
    Comp 3:
    Contains both previous comps.
    Comp 2 is hidden.
    Comp 1 gets “Time Displacement” Effect with max 2 secs displacement. Displacement map is Comp 2.
    When I look at the 2 second mark in Comp 3, the wave-shape looks great.
    I’d like to freeze the instance of Comp 1 at the 2 second mark, so that it looks like this throughout the animation and I can have Comp 2 animate to change the shape.
    But when I use Time-Remap, the trick doesn’t work anymore, because to the Time Displacement effect the timeline looks all the same, too.
    Does anyone know a way around this behavior, or a different way to get the animation I’m looking for?
    Thanks in advance!
    Yours,
    Andra
    Kevin Camp replied 19 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    April 6, 2007 at 4:14 pm
    can you pre-render comps 1 & 2? you can easily set up a postrender action to import and replace usage, so ae will automaticly update comp 3 with the renders of comps 1 & 2. your time remapping setup should work with the rendered footage.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
