Activity › Forums › Apple Final Cut Pro Legacy › Relinking XML from another source
  • Relinking XML from another source
    Posted by Marcus Ellingham on July 11, 2015 at 11:25 am
    Hi there,
    Having a few strange issues with FCP7 at the moment –
    I have an AAF that was exported from Avid (project is 23.98 fps and contains a whole bunch of speed ramps – incidentally I also have a frame cut version). I’ve pulled this AAF into DaVinci resolve and relinked it there where it is displaying perfectly. I’ve then output this as an XML to open in FCP7 – and here is where the problems start.
    It seems when I A/B the offline there are a significant number of shots that are completely off – it’s the same take, but the wrong bit of the take… there doesn’t seem to be any reason for this. I’ve also exported out to a fcpxml and opened in FCPX and it’s perfect there too (I need to cut in FCP7 though as it’s part of a larger project which is all in there)…
    Does anyone have any ideas why this could be?!
    Michael Gissing replied 11 years, 2 months ago 2 Members · 1 Reply
  • Michael Gissing
    July 11, 2015 at 11:59 pm
    With legacy software that has not been developed now for nearly 5 years it is unsurprising that speed ramp shots won’t round trip from AVID, even via Resolve.
    I have had success outputting Resolve back into FCP7 but I render and replace any shots with issues like reframing, speed changes or optical flow.The Resolve xml is sort of there for Premiere so as developments continue with all NLEs and tools like Resolve, it is to be expected that things will break with older legacy software.
