Activity Forums Apple Final Cut Pro Legacy Relinking or adding Audio to clips
  • Relinking or adding Audio to clips
    Posted by Thomas Frank on June 14, 2010 at 8:55 am
    I received a Final Cut Pro project from another Editor that I need to finish up.
    All the clips in the sequence don’t have its corresponded Audio linked. Now is their automated away to add the audio to the video clips in the sequence?? Not sure if it’s me or my imagination… but I recall that this process exist within Final Cut Pro…
    John Fishback
    replied 16 years, 2 months ago
    2 Members · 3 Replies
  • John Fishback
    June 14, 2010 at 6:52 pm
    Sometimes FCP will find other clips in the same folder when you reconnect the first clip. Other times you have to do each separately. Were the audio clips merged with the video or separate?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Thomas Frank
    June 14, 2010 at 7:22 pm
    The footage was captured with Video and Audio, all the clips and master clips are connected in Final Cut Pro.
    The issue is the previews Editor unlinked all the Audio with the Video in the Timeline and delete the Audio from the timeline.
    But I need the Audio back in the Timeline with its corresponding Video.
  • John Fishback
    June 14, 2010 at 10:14 pm
    The good news is you should be able to match frame each clip in the timeline and re-attach the audio. The bad news is it’s one-at-a-time. It’s possible you could use Automator to speed this up, but I can’t tell you how to do that. However, there’s a COW tutorial about Automator.
    John
