Activity Forums Adobe Premiere Pro Relinking Media, now picture is out of sync with Grey danger stripes
  • Relinking Media, now picture is out of sync with Grey danger stripes
    Posted by Aemilia Scott on November 25, 2015 at 7:35 am
    Oh man, this is a pickle.
    I’ve been working offline with offline clips, and now I’m ready to relink to some ProRes 4444 files (cropped with handles) from my colorist. Upon trying to offline these clips and relink them, many are showing up totally out of sync. In the project window I’m looking at timecode for my offlines, and timecode for the cropped colorist clips, and it’s all there. The timeline of the cropped clips sits nicely inside of the larger dailies I’ve been using. It seems like they should sync just fine according to timecode. However in the timeline, the first instance of the clip is all danger bar, and the second instance of the clip is danger bar for a small fraction, and where the picture pops in is not the actual beginning of the clip as I can see it if I open it by itself.
    I’m working against a deadline now and I really need to get a render made. Any ideas about what I’m doing wrong here? Any help would be a huge life-saver.
    Aemilia
    Tim Kolb replied 10 years, 9 months ago 4 Members · 4 Replies
  • Tero Ahlfors
    November 25, 2015 at 9:18 am
    Do the framerates and length match? The stripes mean that the files are different length than they were. This can happen if you relink interpreted media without using the “preserve interpret footage settings” checkbox in the link media settings.
  • Aemilia Scott
    November 25, 2015 at 6:36 pm
    The files have the same framerate. However, as I said they have different lengths because these are shortened files with handles from colorist. in both files I can see the timecode present, so my sense is that they should have synced properly based on that.
    The film opens with two instances of the same clip at different moments of the action, so I’ve been playing with that. premiere seems to believe that the reconnected clip doesn’t have footage in the same spot — that is, the danger bars end and the footage “begins” in the same place for both. in the first instance, the footage is entirely bars, and the second instance the footage is 1/4 bars and then picture. so it would seem it’s using *some* logic to sync, just not the correct logic.
    I’ve included the properties below of the two files. first, is the proxy, and second is the colored MXF.
    File Path: /Volumes/[…]/CAM A/A002_C006_07103A.mov
    Type: QuickTime Movie
    File Size: 761.80 MB
    Image Size: 1920 x 1080
    Frame Rate: 23.976
    Source Audio Format: 48000 Hz – 24 bit – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:00:35:10
    Pixel Aspect Ratio: 1.0
    QuickTime Details:
    Movie contains 1 video track(s), 1 audio track(s), 0 closed caption track(s), and 1 timecode track(s).
    Video:
    There are 850 frames with a duration of 1001/24000ths.
    Video track 1:
    Duration is 0:00:35:10
    Average frame rate is 23.98 fps
    Video track 1 contains 1 type(s) of video data:
    Video data block #1:
    Frame Size = 1920 x 1080
    Compressor = Apple ProRes 422 (HQ)
    Quality = Most (5.00)
    Audio:
    Audio track 1 contains 1 type(s) of audio data:
    Audio data block #1:
    Format = 24 bit – Stereo
    Rate = 48000 Hz
    Compressor = 24-bit Integer
    Timecode:
    Timecode track 1 contains 1 type(s) of data:
    Timecode data block #1:
    Start Time = 00:00:00:00
    Reel name = A002_C006_07103A
    File Path: /consideratione////Volumes/Lacie Underalls/FOR A GOOD TIME – Offline/FAGT_from_CO3_20141016/DNX-HD-350/A002_C006_07103A.mxf
    Type: MXF
    File Size: 445.17 MB
    Frame Rate: 23.976
    Source Audio Format: 48000 Hz – 16 bit – Stereo
    Total Duration: 00:00:10:11
    Pixel Aspect Ratio: 1.0 (1.0)
    MXF File details:
    Wrapper type: MXF OP1a (type: SingleItem SinglePackage MultiTrack Stream Internal)
    File generated by: Adobe Systems Incorporated, Adobe Media Encoder (9.0.0)
    Compression ID: DNxHD 1080p 440 10-bit
    Effective Video Bitrate: 352 Mbps
  • Alex Udell
    November 29, 2015 at 1:03 pm
    Unfortunately, no…
    relinking to a media set with different media durations will not simply match by the timecode…
    you could import the second set and “replace” events on the timeline with your shortened events…
    but don’t relink you media set to the new media…
    take a look at this:
    https://www.retooled.net/?p=253
    hope this sheds some light…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Tim Kolb
    November 29, 2015 at 4:17 pm
    Yes, as Alex states, you can’t hold in/out points when relinking to clips of a different length than the offline proxies.
    While Premiere Pro reads timecode, in and out points seem to be saved as ‘trims’ in relationship to the original clip length….change the media length, slide the ‘trim’ points.
    TimK,
    Director, Consultant
    Video Producer at I-CAR
