Activity Forums Adobe Premiere Pro Relinking LUTS
  • Relinking LUTS
    Posted by Michael Duff on January 5, 2020 at 10:41 pm
    Hi – wondering how we go about relinking LUTs when a project is shared between two systems?
    Example – I’ve just done a grade and I now want to send the project file back to a colleague so that he can render it out. He has all the source footage and everything. Relinking footage is no problem … but what is going to happen with LUTs? I have a handful of custom LUTs that he will need to connect.
    Michael Duff –
    Bearcage Productions, Australia
    http://www.bearcage.com.au
    Mads Nybo jørgensen replied 2 years, 8 months ago 4 Members · 5 Replies
  • Greg Janza
    January 6, 2020 at 12:24 am
    Export each customized LUT as a preset effect and then send those exported preset effects to your partner to import into his/her system.
    https://www.linkedin.com/in/tmprods
    tallmanproductions.net
  • Michael Duff
    January 6, 2020 at 8:50 pm
    Thanks for the reply … in this case he would need to reapply the preset to each clip?
    We have a 2hr program with different LUTs and grades throughout … I was hoping he could just open my project – reconnect the media – hit render – so that I don’t have to upload a 2hr prores files. Possible?
  • Therry Raj
    December 23, 2023 at 3:36 pm
    Hi Duff
    Did you find an answer to your question? I have the same issue and i could find any solution.
    I recorded a video to my question so you can see.
    Any help to solve the issue highly appreciated.
    Thank you.
    https://youtu.be/CR8lVB0jz3o
  • Therry Raj
    January 3, 2024 at 1:53 am
    Nobody!??😳😳
    January 3, 2024 at 2:31 am
    Hey Therry,
    I don’t often share Luts around.
    However, there is an interesting Adobe Thread here from early 2023 (pre-2024 version of Premiere Pro).
    Just make sure that you read to the end of it, as there are some essential information.
    https://community.adobe.com/t5/premiere-pro-bugs/relink-luts/idi-p/13515618
