Activity Forums Apple Final Cut Pro Legacy Relinking Clips with NEW CLIP NAMES
  • Relinking Clips with NEW CLIP NAMES
    Posted by Joe Taylor on October 26, 2009 at 5:31 pm
    Hello All,
    Is there a way that one can re-link a clip to their time-line AFTER or IF they have changed the name of the clip? In our current project there are a number of clips and media that have to have their names changed– the clips are the same, just new names. However, that media is now shown to be offline.
    I would think that since that media itself is the same, just the name has been changed, that it would be fairly easy to relink or re-connect to the clips in the time-line.
    Thank You
    Joe Taylor replied 16 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    October 26, 2009 at 5:38 pm
    If you changed the names of the CLIPS…then FCP will still know the original name of the media file and be able to reconnect fine. BUT, if you changed the name of the media file, on the Finder level, then you are up a creek. FCP will not be able to find that…you will have to actually know what clip goes to what media file, and then turn off the EXACT NAME option in the Reconnect window.
    if you must rename media files and clips, please please PLEASE use the RENAME option in FCP. Rename the clip, then highlight that clip and go MODIFY>RENAME>MEDIA FILE TO MATCH CLIP. Never ever rename the files on the Finder level. That’s a hanging offense.
    Shane
  • Joe Taylor
    October 26, 2009 at 6:06 pm
    Thanks Shane,
    I have only changed the name of one media clip, as a test, before jumping in and renaming everything, so no damage has been done. I just haven’t had any luck finding the info needed before going any further.
    Thanks for your help.
