Activity Forums DaVinci Resolve Relinking Avid sequence in Resolve that uses Subclips.
  • Relinking Avid sequence in Resolve that uses Subclips.
    Posted by Bryce Mcnamara on April 26, 2016 at 11:12 pm
    Hi there,
    Could somebody please help me out with this issue.
    My workflow starts in Resolve. I create ProRes proxy files named exactly the same as the source files. These are then sent to Avid to edit a sequence.
    If I edit directly using those clips – ie. without subclipping – and send back an AAF, everything relinks perfectly in Resolve.
    If I use subclips, the clips in the Avid sequence have names that no longer match the original source footage and this AAF version does not relink in Resolve.
    I feel like there’s an essential step I’m missing in solving this issue. There must be a simple way to use subclips and still link easily back to the source files in resolve.
    I really need to sort this out for an upcoming project where subclips will be used, any advice or assistance would be greatly appreciated.
    Cheers
    Glenn Sakatch replied 10 years, 4 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    April 27, 2016 at 6:46 pm
    can you relink your avid sequence back to the original clips before you send it to resolve?
    (I don’t do a lot of subclipping, so just spit ballin here)
    Glenn
