Activity › Forums › Avid Media Composer › Relink Resolve graded 4k files back to Avid MC 8.3
Posted by Sabri Liefert on February 10, 2015 at 11:44 amHello,
i imported a 4k .aaf timeline from MC to Davinci Resolve.
Graded the files.
Now we want to relink the graded 4k files back in MC.
We tried several settings in the relink dialog. But its not relinking. Perhaps there is a problem with the clip length/starting point?
Is there an other workflow to get the graded files back in place in MC?Eric Santiago replied 11 years, 6 months ago 4 Members · 5 Replies -
Bill Ravens
February 10, 2015 at 11:47 amTo get a successful relink, you have to be sure the timecode and tape name match.
Michael Phillips
February 10, 2015 at 1:52 pmSeeing as it was a roundtrip from MC to start, it will use the same source ID’s available to it so one has to hop they match. What I do is once I have color corrected the timeline in Resolve and rendered the files, I go back to the edit page, highlight the sequence in the timeline tab and export AAD. Not NEW AFF! But AAF. This takes the existing AAF that came in and only changes the pointers to the new media leaving all tracks and VFX In place, even if it could not interpret them. YOu will see that the sequence name will now have (Resolve) added to it.
With the rendered mediafiles in a proper MXF/ folder structure, import the AAF(Resolve) sequence and it should just link up to its own rendered media.
Only on very few occasions where conform was back to camera originals and the chance of changing REEL ID might occur that you need to do a “relink to selected” and ensure that TAPE or SOURCE FILE name is properly selected to match.
Michael
Eric Santiago
February 10, 2015 at 8:47 pmI just did a test using UHD AAF to Resolve 11.2.
I selected DNxHR 444 and rendered it to a new folder.
Then dragged the new AAF and rendered files to a new MediaFiles bin to avoid clutter.
The files didnt load automatically but a drag and drop to a new bin (again to avoid clutter) imported all the files and noticed the AMA linked R3Ds in that new bin.
The sequence seems intact with my grading test but only plays back at yellow level.
No 4K display to play with at the moment 🙁
Am I doing this right? -
Michael Phillips
February 10, 2015 at 10:05 pmDid you start in MC or in Resolve?
Was it AMA linked in MC, then transcoded?
Or linked to camera orignals in Resolve for the conform?
When you say “dragged new AAF” was it really a “new” AFF or the same AAF used in the conform?AAF should not go into the MediaFiles folder. Only the MXF files. Put the AAF elsewhere like on your desktop to be imported.
DNxH4 at 4K can still have too high a dat rate for your system drives and connectivity, thus the need for yellow mode.Michael
Eric Santiago
February 17, 2015 at 1:34 pmThanks again for your wisdom 🙂
I will try the same steps with just the MXF in the MXF folder and leave the AAF to another.
I did notice that the MXF files being read are the R3Ds (AMA) and not a copy.
I hope that made sense.
