Activity Forums Apple Final Cut Pro Legacy Relink Qts run through compressor
  • Relink Qts run through compressor
    Posted by Christian Kinnard on March 2, 2007 at 5:27 am
    Running thousands of files to create media for an offline. I can’t seem to get final cut to automatically relink them due compressor generating extension. I’ve tried rename-it but then FCP doesn’t recognize it as a QT. I’ve tried hide the extension, like the ones generated by FCP, using Show Info but FCP is still seeing the extension there by not matching the name.
    I’m exporting a batch with the setting “Source Media File” not “Souce Media Extension”.
    I usually force relink, but with this many it will take a full day. Am I missing something obvious?
    On FCP 5.1.2, OSX 10.4.8
    Christian
    Neil Sadwelkar replied 19 years, 6 months ago 3 Members · 2 Replies
  • John Pale
    March 2, 2007 at 6:01 am
    You should use Media Manager for this purpose and not Compressor.
    Then everything will link properly.
    Right tool for the right job.
  • Neil Sadwelkar
    March 2, 2007 at 4:38 pm
    There is a way within Compressor to make it not append anything to the file name. Or you can make a droplet and set it to not name the files that way.
    Else, if you’ve already done it, you can get R-name and rename these files using find and replace or renumber it, or append something before or after the name. Its free.
    Neil
    FCP Editor, Mumbai, India.
    Completely PAL.
