Activity Forums Adobe After Effects relink mpeg footage
  • relink mpeg footage
    Posted by Enginn Heima on September 25, 2014 at 7:34 am
    Hello.
    I’m opening up an old AE project and trying to relink the media gone offline by using the “replace footage” option.
    The media files are mpegs and they were originally shot on a JVC GY-HD100. When I replace a media file, it shows up funkily, stating things as the file being 0,027 fps or the duration only being few frames long etc. When I then double-click on the click from the project window to screen the footage in a source monitor, it’s blank (black monitor). The same thing is happening when I simply open the clip in my QuickTime player, which opens the clip but won’t play it, there is only a blank, black monitor. In VLC player though, I can play it.
    I might add that I’m working on a macosx and on AE6.
    Does anybody have a suggestion for me?
    Best regards.
    Michael Szalapski replied 11 years, 12 months ago 2 Members · 4 Replies
  • Enginn Heima
    September 25, 2014 at 7:43 am
    Here is more informations about the mpeg files:
    Bit rate : 18.3 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 50.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.397
    Stream size : 54.1 MiB (92%)
    Audio
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 25s 152ms
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 1.15 MiB (2%)
    Menu
    Menu ID : 1 (0x1)
    List : 4096 (0x1000) (MPEG Video) / 4098 (0x1002) (MPEG Audio)
    Maximum bit rate : 19760000
  • Michael Szalapski
    September 25, 2014 at 4:08 pm
    What is the full version number of AE that you’re using?
    Although, if you can’t see the files playing correctly in another media player, that’s a pretty good indication that there’s a problem unrelated to After Effects.
    Have you installed any codec packs on the system? (K-Lite and others can cause odd issues like that.)
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Enginn Heima
    September 26, 2014 at 3:00 pm
    Thanks.
    No, no codec packs.
    I went back to AE CS5.5, and there is no problem there… go figure.
  • Michael Szalapski
    September 26, 2014 at 3:23 pm
    Odd. Well, I’m glad you got it working.
    – The Great Szalam
