Activity Forums Apple Final Cut Pro Legacy Relink Media Problem
  • Relink Media Problem
    Posted by Adam Taylor on April 3, 2009 at 1:52 pm
    I was sent a project file and a couple of dvds containing XDCam media files. I copied the files to the raid and then opened the project.
    Having never worked with video from anything other than tape before, i was looking forward to a quicker capture…not so !
    As the files appeared offline i tried relink media but when i selected more than 1 clip,the files refused to show up in the relink window.
    The only way i could do it was highlighting one clip at a time and manually relinking them.
    Is there a way to batch relink these kind of files?
    thanks
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    John Fishback
    replied 17 years, 5 months ago
    3 Members · 4 Replies
  • John Fishback
    April 3, 2009 at 5:41 pm
    This link https://forums.creativecow.net/thread/8/1025552#1025722 may help.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • David Bogie
    April 3, 2009 at 5:43 pm
    Ooops. Wrong forum.
    Once AE finds one file, it should relink to all in the same directory path. That’s a preference, I believe. sorry, not at my AE machine to check it for you but relinking is covered extensively in the help system.
    bogiesan
  • Adam Taylor
    April 3, 2009 at 8:17 pm
    thanks John, but that post has nothing at all to do with the problem i mentioned. I’m not tryign to transcode to another format, just get FCP to link to the media!
    Adam Taylor
    Oldham, UK
  • John Fishback
    April 3, 2009 at 8:27 pm
    I’m not that familiar with XDCAM, but I was wondering if it might work like P2 Log & Transfer. With P2 if you mount the volumes with the MXF files in the L&T window, you can then batch capture clips in the Browser. Maybe there’s an analagous way to do this with XDCAM. Just a thought.
    John
