Activity Forums Adobe Premiere Pro Relink media –> Audio Interpretation Lost?
  • Relink media –> Audio Interpretation Lost?
    Posted by Ben G unguren on February 18, 2013 at 7:09 pm
    I have a workaround, but I think there must be a better way:
    – QT files, Stereo L/R audio, interpreted as DUAL MONO in Premiere CS6.
    – During the edit process, some of the source media has to go offline, so we SKIP it when opening the project.
    – Later, when the media is available again, select the media folder in Premiere, choose Link Media…
    – The re-linked files are there, but the audio interpretation is back to STEREO L/R!
    I don’t understand why this is the default behavior — if it is possible to maintain the interpretation when re-linking, why wouldn’t it?
    The relatively painless workaround is to export the entire project file as a FCP XML, make a new PPRO project, import the XML into PPRO, locate the source files during the XML import process, and – ta da! – the Dual Mono interpretation is preserved.
    Can anyone comment on what’s going on here? Perhaps we should have clicked OFFLINE instead of SKIP when opening the project; we haven’t tested it. And I know I could just re-interpret everything in the project window, but this would be impractical at best whenever there are multiple interpretations with various sources. I only want to set all my interpretations once!
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Ben G unguren replied 13 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
