Activity Forums Maxon Cinema 4D Relief object texture problem
  • Relief object texture problem
    Posted by Jake Martin on March 3, 2013 at 5:57 pm
    Hi
    I am trying to make a globe with relief texturing
    In cinema I have a relief object using a geotiff of the globe to displace it.
    I have a jpeg of the earth in the color channel as a material and this all works fine. It sits perfectly over the displaced geometry but as soon as a click spherical the material goes all out of alignment.
    No matter what I do I cannot get the material to align with the displaced geometry when it is spherical.
    Can anybody help, I’ve been at this for days and I’m getting nowhere.
    Cheers
    Jake
    Jake Martin replied 13 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 3, 2013 at 11:40 pm
    what mapping is being used for the color jpeg texture? It is probably UVW by default, which would be fine for the flat projection but it should be changed to Spherical when you make the Relief spherical.
  • Jake Martin
    March 4, 2013 at 7:58 am
    Thanks Brian but I actually figured it out.
    I offset U coordinate on material tag by 25% and it worked
    Cheers
    Jake
