Activity › Forums › Sony Cameras › Reliable link to EX1 firmware update??
Mark steven replied 2 years, 3 months ago 87 Members · 287 Replies
Andy Usac
March 18, 2012 at 3:06 amThanks, wish it was there earlier. I started on 1.05, and went to 1.11. It went to 100% but gave me the dreaded replace the board errors. I then attempted to work my way through all of the firmwares just to try. Each update got worse and worse with error codes showing up if the screen came on. After 2.5 hours I was able to get 1.05 to take correctly again. I tried again with the same issues. I went back to 1.05 again, and then tried to jump straight to 1.25. It worked that time for me. So I am safely at 1.25.
Thanks -
Panagiotis Feretos
March 22, 2012 at 9:52 amHello Julian
i’ve tried to upgrade my EX1 from 1.05 to 1.26
(all done by the book) and the camera is now resting
for three weeks at the local sony service in Greece
having Dmitry’s camera symptoms.
I wonder if your magic link may be useful for me too
Panagiotis
My email add. : pferetos@gmail.com -
Julian Masters
March 22, 2012 at 10:24 pmHi Panagiotis.
I’ve sent you a Dropbox link containing all the files.
You should hopefully be able to go back to 1.05, and then go up one at a time.
1.10 goes through very quickly without any errors, but afterwards it still says the camera is on 1.05
I started to bypass that version, but I’ve recently found a couple of cameras that wouldn’t upgrade to 1.11 correctly unless I had flashed 1.10, so I recommend using it.
I assume it does a minor upgrade to one of the “modules” inside.Good luck.
Julian.
Panagiotis Feretos
March 26, 2012 at 10:21 amHi Julian
I want to thank you for the really magic link and
Yes !!!!
i’ve done it with a lot of help from my friends.
Here are the good news:
after spending many hours trying to install 1.05 with fully disappointing results
of none communication between the camera and the PC,
John (my computer freak friend) said :”do you still have that old laptop of yours?”
and yes it worked !!!
The original “windows XP” is what the camera needed to let 1.05 be installed on it.
All of the rest was a piece of cake. Just following the updates step by step as you sent
it.The PDFs of each update is useful too.
Thanks again
Panagiotis -
Benamir Mujanovic
April 27, 2012 at 8:49 amJulian ,
I would appreciate the links to the files. I have 1.03 currently running on my camera. Could you please send me your link. I tried to upgrade straight from 1.03 to 1.26 and now I have e-13050 error every time I puit the sxs card inside. I would like to go back to 1.03 and then send it to sony to do the firmware update to 1.26 -
Julian Masters
May 22, 2012 at 10:20 amHi Benamir.
I did reply to you the following day (and again about a week ago) but my posts didn’t seem to get through the moderators.
If you let me know your email address then I can invite you to Dropbox.
Regards,
Julian. -
Igor Jeminovic
June 25, 2012 at 2:15 pmplease cane give me a link for v1.05.i have error e17003/e15030. thanks
Igor Jeminovic
June 25, 2012 at 4:20 pmPlease Julian Masters can you sand mr link of Dropbox ,so i can back to firmwre v1.05,because i have error E17003/e15030 because i thraid to upgrde to v1.30,stupid of me.Please help my mail is rogya@verat.net.
thancks -
Julian Masters
June 25, 2012 at 9:25 pmDropbox link sent.
Remember if you get back to 1.05 and do the update, then 1.10 doesn’t seem to do much (it still says 1.05 afterwards). However without doing it I have had problems.
Also, as far as I’m aware the latest firmware is 1.25, unless 1.30 has just been released.
Good luck.
Julian.
