Activity Forums Adobe Illustrator Release to Layers doesn´t work
  • Release to Layers doesn´t work
    Posted by Sergio Juyak on April 1, 2009 at 9:56 pm
    I have autotraced a number of objects in AI. I expanded the trace and ungrouped them, so they are all individual path layers. I need to bring them into AfterEffects so I select them all and “Release to Layers Sequence.” I then try to un-nest the layers by dragging them out of the parent layer and AI won´t let me. Release to Layers Build yields no results either.
    I notice that when I do “Release to Layers,” the path layers do not change label colors, and seem to remain .. so it seems AI isn´t releasing them. I don´t know why. I can drag each object to a new layer manually, but this will take hours… any ideas?
    Running AI CS3.. I think this is Vista but it´s not my comp.
    thx
    Ford Filomeno replied 4 years, 10 months ago 5 Members · 4 Replies
  • Wynne Bernadette
    June 25, 2017 at 2:27 am
    Hello, I know it has been 8 years. But in case people are looking for the answer, I got the solution, 8 years after.
    You have to click the main layer (JUST the main layer) and Release to Sequence. Selecting them all would mean you’re trying to release each path to separate layers, which was the thing that doesn’t compute in Illustrator.
    Hope that helps.
    Wynne
  • Jonathan Perkins
    July 18, 2019 at 5:08 am
    Epic.
    I just saw a YouTube video which instructed me to “target everything” and then Release to Sequence, which didn’t work, and then I was completely stuck.
    SO GLAD you responded after 8 years — you are right, it totally worked to click JUST main layer and then Release to Sequence.
    Thank you!
    Jonathan
  • Carlos Alcala
    February 3, 2020 at 4:14 am
    Thanks a bunch! No matter how long it can take, is always great to have people like you around!
  • Ford Filomeno
    October 28, 2021 at 3:06 pm
    These kinds of help are timeless! Saved me a ton of time. Thanks for getting back to this!
