Activity Forums Adobe After Effects Expressions Relative Position Shenanigans
  • Relative Position Shenanigans
    Posted by Jon Mitchell on October 15, 2013 at 3:51 pm
    Hello! First posting, have used these forums oh-so-many times for expression help. They actually have led me to crafting an expression that almost works, but not quite and I cant figure out why.
    The situation: 2 layers, one “parenting” the other and I want the “child’s” position to change relative to the parent starting at a certain time. (NOTE: the layers are not actually set as parent and child, they are only linked by the following expression)
    I used this expression:
    freeze = [960, 540]
    text = thisComp.layer("Show1").transform.position;
    timetoStart= 5.1
    if(time > timetoStart){
    text-sub(text, freeze);
    }else{freeze;}
    I figured the simple difference of a difference calculation would do the trick, but the expression just yields a constant 960, 540 as the position. I double checked and sub(text, freeze) does yield the proper difference (and it’s dynamic) but when I try to subtract the dynamic difference from text if yields a constant value.
    What’s going on? 🙁
    Jon Mitchell replied 12 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 15, 2013 at 4:22 pm
    I think you need to reference where the Show1 layer was at timetoStart.
    change this:
    to this:
    text – text.valueAtTime(timetoStart) + freeze;
    Dan
  • Jon Mitchell
    October 15, 2013 at 4:28 pm
    Dan,
    Brilliant. Worked like a charm.
    Thank you!
    -Jon
