Activity Forums Adobe After Effects relationship btwn Camera and Comp sizes
  • relationship btwn Camera and Comp sizes
    Posted by Alpay Kasal on June 4, 2005 at 6:43 am
    Hello all. I feel like I should know this after so much experimentation but I am thoroughly confused right now…
    What would be the science behind the camera settings when going from the HDTV comp preset to ntsc DV preset? I have some complicated 3D projects where everything was built using the HDTV preset. I’d like to downconvert the project and rerender but ofcourse when I simply change comp settings, my view of the 3D world shrinks dramatically. up until now I have been simply “eyeballing” new camera settings to re-frame things.
    I’d like to know if there is some math I can use to apply new camera settings to go with the new comp settings so that I’m basically dealing with the closest rendered output in the end (ignoring ofcourse the diff between 16:9 and 4:3).
    Thanks. whew.
    Alpay Kasal
    Artist/Engineer
    https://www.NYCRenderfarm.com
    Alpay Kasal replied 21 years, 3 months ago 2 Members · 3 Replies
  • Alpay Kasal
    June 4, 2005 at 9:36 am
    ok just did another one… in the HDTV version of the project, the 3D camera zoom is at 1000. after changing comp settings to ntsc DV 720×480, i had to set the camera zoom to 350 to get what seems to be the same framing. Thanks for any help people.
    Alpay Kasal
    Artist/Engineer
  • Chris Smith
    June 5, 2005 at 3:29 pm
    Just drop your HD comp into an SD comp and scale the comp size using the normal scale parameter.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Alpay Kasal
    June 5, 2005 at 7:35 pm
    Yeah, that works but then all processing is happening at 1920×1080 resulting is super long rendering. by changing project settings for all comps to 720×480 rendering times change drastically. Eyeballing it isn’t sooo bad but I thought someone could explain the science of the camera to me… thanks for the replies.
    Alpay Kasal
    Artist/Engineer
