Activity Forums Adobe After Effects relationship between z axis and focus distance
  • relationship between z axis and focus distance
    Posted by Martin Earle on May 5, 2009 at 9:24 pm
    Hello All,
    Does anyone know what the exact relationship between the position of a layer on the z-axis and the focus distance of an After FX camera (which is measured in pixels). At the moment I’m judging focus by eye but it would be good to me a bit more scientific about it!
    Thanks very much
    Martin
    Jeremy Allen replied 17 years, 4 months ago 3 Members · 2 Replies
  • Bartek Skorupa
    May 5, 2009 at 9:59 pm
    Select camera, hit “a” twice. You’ll find “focus distance”
    That’s all the science you need. The layers that are exactly that far from the camera are in focus.
    Bartek Skorupa
    Warszawa, Poland
  • Jeremy Allen
    May 5, 2009 at 11:35 pm
    You may already be doing this, but it helps to use a left, right or top view. As you adjust the focus distance you can see it moving closer to or farther away from the camera. When you see the focal plane touch the target layer, optimum focus is achieved.
    There are also some expressions that you can use to attach the focus distance to a null. Then you can move the null around whenever you need to change the focus distance.
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2
    AE CS3
