Activity Forums Adobe After Effects Expressions relational movement without the initial jump
  • relational movement without the initial jump
    Posted by Sam Mattson on June 9, 2014 at 9:36 pm
    I’ve probably just been looking at this too long. I’m sure this is a simple fix.
    Example: 2 nulls in a comp positioned anywhere. Null 1 and Null 2. I have this code applied to the position of Null 1. The code tells Null 1 to move in X as Null 2 moves in Y.
    However, when applying this script, Null 1 jumps its initial position X to match Null 2’s Y. I want Null 1 to keep its initial position and not jump, regardless of where Null 2 started.
    xPos=transform.position[0]+(thisComp.layer("Null 2").transform.position[1] - transform.position[0]);
    yPos=transform.position[1];
    [xPos, yPos]
    Dan Ebberts replied 12 years, 3 months ago 2 Members · 4 Replies
  • Sam Mattson
    June 9, 2014 at 10:03 pm
    On other words, I know I can write it like this:
    variance = 640-thisComp.layer("Null 2").transform.position[1];
    xPos=transform.position[0]+variance;
    [xPos, yPos]
    But I’d like to not have to type the manual value of “640” in if I applied this script to something else with a different Y value.
  • Dan Ebberts
    June 9, 2014 at 10:29 pm
    I think you’re after something like this:
    p = thisComp.layer(“Null 2”).transform.position;
    y = p[1] – p.valueAtTime(0)[1];
    value + [y,0]
    Note that it won’t do anything until you animate Null 2.
    Dan
  • Sam Mattson
    June 10, 2014 at 3:02 am
    I had coded that too, but I was hoping to find the initial position without looking at time, as the nulls I’ll be moving are on a character rig. Oh well, I guess I’ll hand enter the initial values.
  • Dan Ebberts
    June 10, 2014 at 3:14 am
    Yeah, one way or another, you need a reference point for Null 2.
    Dan
