Activity › Forums › Sony Cameras › reinterlacing 60p
  • reinterlacing 60p
    Posted by David Burch on May 14, 2008 at 1:15 am
    I apologize if this issue has been covered, but I’ve been searching everywhere and can’t seem to find and answer.
    I am working on several projects shot with two EX-1 cameras and one Z1. The final output for these projects are all standard DVD. The Z1 footage was recorded in standard definition, since I have had issues downconverting 1080i footage shot with that camera in the past using Final Cut Pro. Being that this is the first time our company has used the EX-1, the decision was made to shoot 720p at 60fps. The idea was that this format should theoretically produce the best results when down-converted to 29.97 interlaced scan.
    The problem I am having is in the conversion process of the video shot with the EX-1s. Theoretically, whatever software is doing the conversion should be able to pull information from alternate frames to create a smooth interlaced image. However, I can’t seem to make this happen. Every attempt I have made has resulted in both fields containing information from the same source frame. In other words, the video plays and acts like a 30p image. Also, when paused on a single frame in FCP the image doesn’t jutter like it should were it truly interlaced.
    Does anybody know how I can pull a true interlaced image from my 720p footage? Any help would be appreciated…thanks!
    Marco Solorio replied 18 years, 4 months ago 2 Members · 1 Reply
