Activity Forums VEGAS Pro Reinstall question
  • Reinstall question
    Posted by Ron Whitaker on June 14, 2015 at 11:35 pm
    I think at this point I am going to reinstall Vegas Pro 13.
    My question is, what are the filenames, and where are they, that control preferences and the layout I’ve set in Vegas. I want to keep those.
    Also, are these directions updated and accurate as to how to properly uninstall and re-install?
    Any other files I should set aside to keep?
    Thank you.
    John Rofrano replied 11 years, 2 months ago 3 Members · 2 Replies
  • Russ Froze
    June 15, 2015 at 9:16 am
    That question came up a 6 or 7 months back. Do a search in the Vegas forum.
    Russ Froze
  • John Rofrano
    June 15, 2015 at 11:33 am
    Vegas Pro preferences are kept in an area of your hard drive that is normally hidden. You can get to it using an Environment Variable %AppData%. This works in a Command prompt or with the Windows Explorer. A complete uninstall and reinstall will not affect them. All of the preferences for Sony software are under:
    %AppData%\SonyThere you will find your custom render templates under:
    %AppData%\Sony\Render TemplatesPreferences for all Vegas Pro versions are in a folder called “Vegas Pro” with a subfolder for each version number. So Vegas Pro 13.0 preferences are under:
    %AppData%\Sony\Vegas Pro\13.0This will have your Windows Layouts, Keyboard Shortcuts, Explorer Favorites, etc.
    As I said there is no reason to back these up because they will not be touched no matter how many times you uninstall and reinstall. If you are moving Vegas Pro to a new computer, these are the files that you want to take with you.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
