Activity › Forums › Apple Final Cut Pro Legacy › Reinstall Plugins
  • Reinstall Plugins
    Posted by Dustin Parsons on November 17, 2008 at 9:57 pm
    I recently had to restore my hard drive from a Time Machine backup. Everything seems fine except apparently FCP lost the plugin Soft Focus (and maybe some others, this is the first I’ve noticed though).
    In the folder Macintoshi HD > Library > Application Support > Pro Apps > Internal Plug-Ins the FxPlug folder was missing. I found that someone had uploaded the folder contents in this thread https://forums.creativecow.net/thread/8/982062#982076 so I downloaded it and dropped it in. Nothing changed. Soft Focus still does not appear in the Effects list under Blur.
    Is there something I have to do in to install or direct FCP to the Filters.bundle file?
    Thanks for your help!
    Mac Pro | Leopard 10.5.5
    2.66GHz Dual-Core Intel Xeon | 4GB Ram
    Final Cut Pro Studio 2 | Avid Media Composer
    Dustin Parsons replied 17 years, 10 months ago 2 Members · 4 Replies
  • Tom Matthies
    November 17, 2008 at 10:51 pm
    If a plug-in is an FxPlugin I normally put mine in the HD>Library>Plug-ins>FxPlug folder. If I put them into the “normal” plug-ins folder you were referring to, they won’t show up in FCP.
    Tom
  • Dustin Parsons
    November 17, 2008 at 11:03 pm
    Where would I find the HD folder? Spotlight couldn’t find it so I’m assuming that’s the folder I lost.
  • Dustin Parsons
    November 17, 2008 at 11:04 pm
    Never mind, I just realized that you were referring to the Hard Drive.
  • Dustin Parsons
    November 17, 2008 at 11:16 pm
    That didn’t work either. So far I’ve put the files in:
    Macintoshi HD > Library > Application Support > Pro Apps > Internal Plug-Ins > FxPlug
    Macintoshi HD > Library > Application Support > Final Cut Pro System Support > Plug-Ins
    Macintoshi HD > Library > Plug-Ins > FxPlug
    Final Cut Pro will not read the Finlters.bundle in any of these locations… unless I have to do something other than just put the file in one of those folders. Thanks again for your help.
