Reimport files final cut 7
hello everyone. i really need help since i couldn’t find a solution over the net.
i used the log and transfer tool with final cut pro 7, and imported files as pro res proxy.
now i’m done editing, and i want to reimport the files as pro res HQ. through the media manager
i suceeded to make a new project containing only the sequence that i want to export.
i also managed to find my way to the Log and Transfer tool again, and Final Cut found all of the media in it’s origin file structure that i keep on an external hard drive. and here is the problem:
Final Cut reimporting all the media and not just what i need for the sequence, and that is a lot of media.
anyone can help with that?p.s
i have many folders structure that are the same, and all of their names are “PRIVATE” as it comes
like this from the camera i use. is this might be a problem for Final Cut to know the differences?thanks a lot and good day
