Activity Forums Adobe After Effects Regular mask vs. RotoBezier
  • Regular mask vs. RotoBezier
    Posted by Ace Billet on July 27, 2005 at 3:33 pm
    Just found today the RotoBezier feature of AE (hurray Shake lovers)
    and wanted to make sure, is there any difference between the two methods ?
    I find it much easier than pulling those bezigon handles, but am still new to this method.
    and now 2 cheap puns:
    Let bezigons be zigons.
    “Is it too much mask ?” (the roto anthem by Bad Religion)
    cheers
    ace
    Intel Inside, the world’s most popular warning label.
    Scott Frizzle replied 21 years, 1 month ago 3 Members · 2 Replies
  • Chris Smith
    July 27, 2005 at 5:32 pm
    I mostly use the B splines (“Rotobezier”) rather than the bezier especially for “organic” shapes. I use the bezier when doing hard edge shapes. I find that B splines are easier to animate because for they react the way I expect them to and are more simple creatures to deal with.
    But that’s just me (probably mostly because I’m not to good with bezier).
    Chris Smith
    https://www.sugarfilmproduction.com
  • Scott Frizzle
    July 27, 2005 at 6:06 pm
    I agree; in most cases rotobezier masks are easier to animate. With regular bezier points, in practice you are sometimes having to move 3 points (each point on the mask along with its two control handles) for every one point that you’d have to move with rotobezier. THis can really add up on a complex mask. If you’re not having to make geometric masks, rotobezier is the way to go for sure.
