Activity Forums Apple Final Cut Pro Legacy Registry error on Final Cut Pro OSX 10.7.5
  • Registry error on Final Cut Pro OSX 10.7.5
    Posted by Javier Lopez on November 22, 2012 at 2:52 pm
    Hello gentleman,
    I have an issue with Final Cut Pro, 2 days a go started to give me a “Registry Error” message along with: Make sure the program is properly installed, can anyone please provide any suggestion to solve this issue?. FCP gets stuck on this error window.
    Regards,
    Javier.
    Javier Lopez replied 13 years, 10 months ago 3 Members · 4 Replies
  • Steve Eisen
    November 22, 2012 at 6:23 pm
    [Javier Lopez] “Make sure the program is properly installed, can anyone please provide any suggestion to solve this issue?”
    Re-install the software
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Javier Lopez
    November 22, 2012 at 9:32 pm
    I wanted to avoid “Re-installing”, but I had found the issue, T-racks plugins was the problem, uninstalled the plugin, I had to run “Preference Manager” and “OnyX”, running smoothly again without “Re-installing” FCP and all the plugins.
    Thanks.
  • Michael Gissing
    November 22, 2012 at 9:56 pm
    I hope you didn’t just intall Lion over an older OS. Installing FCS2 on Lion is tricky because it doesn’t have Rosetta. There is a work around and it has been discussed here before so I suggest you search this forum.
  • Javier Lopez
    November 23, 2012 at 2:51 pm
    Hello Michael,
    I did a clean install “Formatting the HD first”, so far I had no issues.
    Javier.
