Activity Forums Adobe After Effects Expressions Regarding Scale Expressions in After Effects
  • Regarding Scale Expressions in After Effects
    Posted by Avinash Sure on March 9, 2019 at 3:55 am
    Hi I am very new to this forum and after effects as well,
    Could anyone please explain how could i write an expression that could do https://www.youtube.com/watch?v=56K06IL6-NE. how can i automatically scale a rectangle based on its value and change the y-axis at the same time based on its rank.
    Kalleheikki Kannisto replied 7 years, 6 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    March 9, 2019 at 8:10 am
    This would be very inefficient to do with expressions, as expressions are evaluated every single frame.
    You should look into data-driven graphics for this instead. Then you can sort the results in excel (or whatever the source of the data is) and include the color of the bar in the spreadsheet (source doc), and use a data-driven template to generate the image.
    Senior Graphic Designer
  • Avinash Sure
    March 10, 2019 at 12:57 pm
    Thank you for the Info , Where could i find such template and how can i convert it into a video with displaying data that changes based on the data .
    March 11, 2019 at 4:27 pm
    You would create the template yourself. Here’s where to start: https://helpx.adobe.com/after-effects/using/data-driven-animations.html
