Activity Forums Adobe After Effects Expressions ‘regaining control’
  • ‘regaining control’
    Posted by Antony Buonomo on September 17, 2009 at 11:39 am
    Hi
    I have linked some audio to a Warp effect to the single letter of a word. As the audio gets louder and softer the letter deforms. However, at the end I want the letter to be its original state, i.e. no deformation from the effect. How do I set up the expression so that at any given point I can nullify its effect and return everything to normal?
    This is the expression on the Warp effect:
    thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”)*1.2
    This is the expression on the Transform effect:
    linear(thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”), 0, 30, 50, 250)
    I can’t really cut the audio as it has to continue.
    Antony Buonomo replied 17 years ago 2 Members · 8 Replies
  • 8 Replies
  • Antony Buonomo
    September 17, 2009 at 1:00 pm
    I guess I am asking; how do you turn off an expression?
  • Dan Ebberts
    September 17, 2009 at 1:17 pm
    If you want to cut it off at a specific time, say 10 seconds, you could do this:
    if (time < 10){ thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider")*1.2 }else{ value } Dan
  • Antony Buonomo
    September 17, 2009 at 1:35 pm
    Thanks Dan, just looking at your site now!
    I’m trying to work out how to add the expression to an Expression Control-Slider and then keyframe that, but I’m getting muddled. If I have an expression for Warp deformation on a layer, what gets linked to what? I have seen tutorials on the Cow, but can’t find the exact piece of info at the moment…
  • Dan Ebberts
    September 17, 2009 at 4:30 pm
    Just replace the warp effect expression you had with the one I suggested. Or am I missing something?
    Dan
  • Antony Buonomo
    September 17, 2009 at 7:47 pm
    I think I am just being unclear or stupid or both.
    I want to ‘tail-off’ the influence of the expression rather than end it specifically at a given frame. I guess this means keyframes, but I can’t work out how to create a slider that controls the audio and still use it in the Warp expression.
    I have a letter ‘o’ pre-composed. On that layer I have a Warp effect. A couple of those parameters are driven by an audio layer. Obviously, as the audio is playing the letter is deformed. Towards the end of the animation I want to bring the rest of the word in – the word to which the letter ‘o’ is the beginning. However, because of the influence of the audio layer on that single letter, the word looks weird. I want all the Warp parameters to be zero by the time the rest of the word comes in, but I don’t want it to be a sudden jump; I want to be able to ease those values into zero over a few frames.
    I thought I could do it simply with an expression control slider but I have a feeling I have to create a variable first…?
    Thanks for hanging in there!
    A
    PS I can send the project if you think it would be clearer.
  • Dan Ebberts
    September 17, 2009 at 8:30 pm
    You certainly could do it with a keyframed slider, but if you know when you want it to happen, something like this should work as well (not tested – but it should be close):
    var beginFade = 10;
    var fadeTime = 0.2;
    var warpVal = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”)*1.2;
    var endVal = 0;
    ease(time,beginFade,beginFade+fadeTime,warpVal,endVal)
    Dan
  • Antony Buonomo
    September 18, 2009 at 11:34 am
    Dan
    As I have a number of effects I would really like to do it via a keyframed slider rather than a hardwired time. Could you please point me towards a correct solution or tutorial using this method?
    As you can see from the image, to get the letter back to ‘normal’, Warp (Bend, Hor & Ver) should all be zero and Transform scale height should be 100. As I can’t divide by zero I don’t know how to get the Bend value to zero and so that expression is broken.
    Appreciate any comments.
    A
    A
    Vertigo Productions
    https://www.vertigo.co.uk
  • Antony Buonomo
    September 18, 2009 at 11:35 am
