Activity Forums Adobe After Effects Refreshing images
  • Refreshing images
    Posted by Tom Silverman on March 2, 2009 at 10:26 pm
    Hiya,
    I have a PSD image used in an after effects composition. However, I want to change the look of this image a bit in Photoshop. Is it possible to refresh the image, so that the same things happen to it (position, scale etc.) but it changes with the changes I have made in Photoshop? i.e.
    Thanks for your help…
    Tommy the Englishman
    Kevin Camp replied 17 years, 6 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 2, 2009 at 11:11 pm
    to make sure i know what you are asking…
    you have a psd in a ae. you want to make modifications to the psd in photoshop and have those changes show up in ae.
    yes, you can make all the changes you want to existing layers in photoshop. the changes you make in ps will show up in ae. if that ae project is open, to see the changes in the psd file, select the file in the project window and choose file>reload footage (or right click file, reload footage).
    the changes should show up in any comps that use that psd.
    i mentioned changes to existing layers…
    if your psd was brought into ae as footage, then you can add or delete layers as much as you want. but, if your psd was brought into ae as a comp, then you will need to import in any new layers by importing the psd as footage, but selecting the layer you want to import, then bringing the new layer into the psd comp… so it can be a little tricky if you need to add layers.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
