Activity Forums Apple Final Cut Pro Legacy refreshing dv/ubcompressed workflow thread
  • refreshing dv/ubcompressed workflow thread
    Posted by Baba Goof on November 8, 2006 at 7:09 pm
    incredible amount of valuable info in the thread but my last question
    went unanswered so i thought i should refresh the thread as it might
    have gotten buried. original thread was:
    workflow questions regarding dv/uncompressed by BabaG on Nov 3, 2006 at 8:38:37 pm
    what i’m gathering is that staying with dv preset is the way to go
    in general. exception would be to create a custom preset, one presumably
    with no compression and at 720×480 rather than the fcp supplied preset
    at 720×486.
    sounds simple enough. one question, however. if a major reason for
    staying in the dv preset is to avoid the recompression in the return
    from uncompressed space, don’t i have to do that anyway, given that
    most of the timeline in question is comprised of full frame supers
    involving two to four layers? if i had a single track of video i’d
    be able to avoid this recompression, as i understand it, but since
    the image is a marriage of several, i’ll have to recompress anyway.
    please confirm or correct me on this.
    lastly, we’re not really sure what the final output will be. the
    filmmaker i’m working with is an artist and, as such, he’s making the
    pieces he wants to make. where they get shown varies from large
    halls to small galleries to broadcast. certainly there will be a
    need to output dv at some times, but there will also likely be
    occassions where dvd is desirable and others where the highest
    quality would be best. in this context i felt that going to an
    uncompressed space early would be good as we could step down from
    it as necessary. our archive would be in this larger format.
    oh yeah, and how does one move an image precisely one pixel down?
    thanks for all the considered input. it’s very interesting.
    BabaG
    Baba Goof replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
