Activity Forums Apple Final Cut Pro Legacy Refresh Nested Sequences?
  • Refresh Nested Sequences?
    Posted by Eddie Brega on October 17, 2005 at 10:55 pm
    When I nest sequences into another and then lay video on top and edit as usual, after a while the nested sequences don’t update themselves properly so the video will be completely off. Sometimes it will be messed up during a dissolve and then once the dissolve is over, it will catch up with itself and play like it should. It happened on a previous project and now again on a current one. Anyone else having this problem? Any way to resolve/work-around it?
    Thanks – Eddie
    Eddie Brega replied 20 years, 11 months ago 3 Members · 4 Replies
  • Bret Williams
    October 17, 2005 at 11:22 pm
    I find the quickest thing to do is to grab the transparency line and drag it down then back up, forcing a rerender/refresh. Otherwise it just links to the old render file, except for where rerendering is needed, like on a dissolve, as you discovered.
  • Kevin Monahan
    October 17, 2005 at 11:33 pm
    Toggling visibility also works. CONTROL+B.
    Yep, it’s in the book and in the seminar….;-)
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Eddie Brega
    October 18, 2005 at 4:21 pm
    Thanks for the quick reply! Worked like a charm!
  • Eddie Brega
    October 18, 2005 at 9:46 pm
    I tried both suggestions and found them to work, but not all of the time. Any other ideas? Thanks.
    Eddie
