Activity Forums Adobe After Effects refresh .aec from cinema 4d
  • refresh .aec from cinema 4d
    Posted by Jason W. miltt on June 12, 2009 at 9:44 am
    is it possible to update changes in my exported .aec from cinema 4d?
    What if you are compositing and have replaced a lot of nulls in your comp and then you reanimate them and the camera too. Do i have to manyally change and update my camera and nulls?
    Thanks.
    Jason W. miltt replied 17 years, 3 months ago 2 Members · 2 Replies
  • Steve Roberts
    June 12, 2009 at 6:33 pm
    It’s possible to refresh assets such as MOV and TIF files, but not an AEC, since the AEC doesn’t reside in the Project window as an AEC file. In other words, there’s no AEC file to click on and refresh — just comps.
    If you change your C4D animation, you have to make a new AEC file and TIF (or whatever) files from C4D. You’d then have to import the new AEC file (and TIFs) into AE, which would give you new comps. You can then copy the null/camera layers from the new comps and paste into the old comps if you want, or work in the new comps.
    Sometimes when you import something into AE, no link is maintained. It’s the same way when importing AEP files. There’s no link there.
    Hope that helps.
  • Jason W. miltt
    June 12, 2009 at 7:13 pm
    I was just wishing that someone might have invented something to automate this.
    Thanks anyway.
