Activity Forums Apple Final Cut Pro Legacy Reformatting AVID FW drive for Mac?
  • Reformatting AVID FW drive for Mac?
    Posted by Chad on February 18, 2006 at 10:26 pm
    Was given a Seagate FW drive that was originally used on an Avid. Want to use it for a project on my Mac, but my Mac’s not recognizing it. Thought I could reformat it but it doesn’t see it at all, not in Disk Utility or System Profile.
    Any ideas?
    Craig Alan replied 20 years, 7 months ago 3 Members · 3 Replies
  • Chad
    February 18, 2006 at 11:30 pm
    appears it’s only recognizing the drive via USB. Worthless…
  • Annaël Beauchemin
    February 19, 2006 at 12:10 am
    Avid on Mac uses standard HFS+ format. On PC it uses standard NTFS. There’s no special Avid format.
    If you don’t see a FW device in system profiler, then either its FW port or your FW cable is busted.
  • Craig Alan
    February 19, 2006 at 4:34 pm
    If the same cable and port work for another drive then they are not the problem. I would reformat it using any combo that does recognise it and then try it again on the problem port. I would also check to see if there is any firmware update from the drive company or the firewire card company.
    OSX 10.3.8; Quicksilver Dual 1 gig; FCP 3.0.4; Sony camcorder vx2000; write professionally for a variety of media
