Activity › Forums › DSLR Video › Reformat
Reformat
Posted by Stephen Smith on September 27, 2010 at 8:38 pmI need to reformat a SD card because it went bad. Do you format it just like you would format a hard drive? Do you format it to FAT16?
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Pete Burger replied 15 years, 10 months ago 5 Members · 5 Replies -
Richard Van den boogaard
September 27, 2010 at 9:52 pmAdvice – do it in-camera. That way you can’t do the wrong thing…
Richard van den Boogaard
cameraman / editor / video marketing consultantBranded Channels
W: http://www.brandedchannels.com -
Ryan Mast
September 28, 2010 at 12:14 amIf it “went bad,” throw it out.
If you want to test it first, I recommend doing a zero-wipe format in Disk Utility, then reformatting it in your camera. If your card is iffy, the zero-wipe will throw an error. And then you throw the card out.
Meteor Tower Films
We make music videos, design video for live theater, and build interesting contraptions. -
Michael Sacci
September 28, 2010 at 2:14 amThe card should always be formatted in the camera. There is a low level format option also.
Stephen Smith
September 28, 2010 at 2:59 pmWhen I put the card into my T2i the camera will not turn on. When I put it into a card reader on my Mac I can see everything on it. So I can’t format it in the camera but I can on the computer.
Stephen Smith
Pete Burger
September 29, 2010 at 11:58 amFAT16 is not usable for your camera, but you can try to format the card with your computer and then try it again with your camera. If the camera recognizes the card, re-format it with the low-level-format option. If not… well… the card my be damaged and you can throw it away
