Activity › Forums › Zaxwerks › Reflector problem
  • Reflector problem
    Posted by Claire Eastham on September 23, 2009 at 4:09 am
    Hi Guys
    Having a bit of a problem with reflector is CS3. Have a Composition I’m creating with a bunch on precomps in the timelines, a “reflective” floor using – of course – reflector, a camera, and a null object which the camera is parented to.
    Problem: When I apply reflector I get a great looking reflection, can adjust the settings, and update BUT if I go to move through the timeline the reflection on the floor is only of the frame I was on when I applied reflector. Thinking it was a user error I reset the plug in, and the frame I was on with the wrong reflection now updated to be correct. But once I moved through the timeline again same problem.
    Any ideas? Am I doing something wrong without realising it…?!
    Any help would be much appreciated.
    Edward Wu replied 17 years ago 2 Members · 1 Reply
  • Edward Wu
    September 23, 2009 at 5:20 pm
    Hi Claire,
    Please send an e-mail to me at ed@zaxwerks.com
    I think I may know what you are running into. You could be running into a compatibility issue with the current version of Reflector and the version of After Effects you are running. Send me an e-mail so I can send you a newer version of Reflector to work with.
    Best,
    Edward
