Activity Forums Zaxwerks Reflector Crashes Mac AE CS3
  • Reflector Crashes Mac AE CS3
    Posted by Brian Walsh on December 3, 2007 at 11:29 pm
    I just bought a 24″ iMac, 2.4GHz, 4GB RAM, and won Zaxwerks Reflector at last week’s AENY. I am running Leopard, 10.5.1, and After Effects CS3 version 8.0. I’ve tried using refector twice now, and it has crashed after a few minutes, each time, just after hitting the Update button (to update the reflection). Any ideas, anyone?
    Gary Lockhart replied 18 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Matt Rhodes
    December 4, 2007 at 1:18 am
    Hi Brian.
    Can you send me your Reflector project
    and give me a few instructions to follow
    in order to replicate the problem?
    Send files to: matt@zaxwerks.com
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
  • Gary Lockhart
    December 5, 2007 at 3:25 pm
    I am interested in a solution as well; I am running CS3 and Reflector on a Core 2 Duo with 4 GB Ram. I posted a question earlier, but have not received a response!
  • Zax Dow
    December 7, 2007 at 9:59 pm
    Someone else had this trouble and discovered that by turning on the Multiprocessing option in the AE pref, he regained stability again.
  • Brian Walsh
    December 8, 2007 at 12:20 am
    I’ll try that out and let you know how it works. Thanks.
  • Gary Lockhart
    December 8, 2007 at 1:27 am
    Tried as suggested, did not work for me. Running on Windows XP platform.
    Also, when I add a Proanimator layer, the reflection doesn’t always show up and AE crashes after awhile. The error message says:
    After Effects error crash occurred while invoking effect plug-in ‘Refelctor’.
    This happened in AE 7 also.
    evangary
  • Gary Lockhart
    December 8, 2007 at 11:44 pm
    Solved the problems. Don’t know which of the following actually did it. Set the hardware acceleration in Windows XP SP2 to about half (found a thread from searching this forum.) Also, re-installed ProAnimator. One or both of these solved my problems.
    evangary
  • Gary Lockhart
    evangary
