Activity › Forums › Zaxwerks › Reflector and Invigorator using Comp Camera: Limitation??
  • Reflector and Invigorator using Comp Camera: Limitation??
    Posted by Brian Charles on January 30, 2008 at 12:16 am
    When I use the Comp Camera in Invigorator then create a floor and apply Reflector to it the reflection is skewed. I have “Hide 2D Layers” unchecked.
    Turning off the Comp camera and updating Reflector shows the reflection in the correct perspective.
    Is this a limitation of Reflector? Or am I missing something?
    I couldn’t find anything about this in the documentation.
    Brian Charles replied 18 years, 8 months ago 2 Members · 2 Replies
  • Matt Rhodes
    January 30, 2008 at 6:02 am
    Hi Brian.
    Make sure your floor layer has the same aspect ratio as your Invig layer — which should have the same aspect ratio as your Comp.
    Unfortunately, when those don’t match, skewing can happen.
    Let us know if that helps.
    Matt Rhodes
    Zaxwerks, Inc.
  • Brian Charles
    January 30, 2008 at 4:16 pm
    Thanks for the info. I may have read this somewhere but had forgotten.
