Activity Forums Adobe After Effects Reflective Surface
  • Reflective Surface
    Posted by Lee Schneider on March 26, 2006 at 5:42 pm
    I’m sure this is quite simple, but I’m having trouble pulling it off. I would like to create a surface that lies across the bottom of the screen that reflects the graphics I animate above them. Something similar to an image reflecting off of water. Aby help wuld be greatly appreciated!
    Lee
    Alexxx replied 20 years, 5 months ago 2 Members · 1 Reply
  • Alexxx
    March 28, 2006 at 12:39 pm
    Hi Lee,
    Let’s say the composition you want to mirror is called COMP_1 and it has some text across the middle. Create a new comp called COMP_2. Drag COMP_1 into COMP_2 twice so you got two copies of COMP_1 in your new comp. Now twirl down the top COMP_1s scale modifier. Click on the little chain-link graphic which means you can now individually resize X and Y. Now simply make Y = -60. Leave X at 100. You’ll see if has flipped your composition AND squished it a bit. Now all you need to do is position it up and down a bit so the bottom and top meet. You can then set the top comp’s transparency to 75% to give it a more reflective look. Try also applying some wave effects if you want a watery look.
    Good luck.
    Alex
    http://www.lightdrop.com.au
