Activity Forums Adobe After Effects Reflections video template
  • Reflections video template
    Posted by Belinda Edwards on August 15, 2008 at 7:11 am
    I was on YouTube.com and seen a template that I would like to have, but my budget is too tight to pay 90.00 for a template. If you look up on that sight, a “reflections tutorial for AE, you will see it. It’s not the one of a picture on a horizontal plane w/ a reflection of a picture. It’s the one that picture fly around and text intos are done during the fly-bys. If you go to http://www.aeprojects.com you will see that it is the number one template. Does anyone know where I can get this other than that website, and if I can get it free somewhere? Or maybe someone wants to sell to me cheaper than $90.
    Thanks alot
    Have a blessed day
    Steve
    Darby Edelen replied 18 years, 1 month ago 4 Members · 6 Replies
  • Roland R. kahlenberg
    August 15, 2008 at 7:57 am
    All you need to do is to make your layer 3D, then duplicate it once. Move the Anchor point for the copy that is going to be the reflection to the bottom, centered. Rotate it 180 degrees around the x-axis. Depending on your setup, another rotation around the z-axis may be required.
    That’s your reflection. Parent the reflection layer to the ‘proection layer so that they stay together should you commit to transformations later on. Adjust Opacity to the reflection layer.
    To make your reflection more reslistic than what you see in the video, add a mask and feather it to create a fall-off for the reflection.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Luka Tisler
    August 15, 2008 at 1:57 pm
    You can find tutorial as well as free preset here.
  • Belinda Edwards
    August 15, 2008 at 3:11 pm
    Neither of the posts are the one I am refering to. This is the one that I am refering to: https://www.youtube.com/watch?v=F-GmYaiIuuA.
    But, thanks for the quick responses.
    Steve
  • Darby Edelen
    August 15, 2008 at 7:54 pm
    I think it’s ridiculous that they would charge $90 for that template and do the reflections incorrectly! For shame, but I guess there have been more egregious failures of business ethics in the past 🙂
    Here’s my recommendation for your reflections. Position and animate ALL of your 3D layers (without a camera or lights) in one composition. Use a 3D ‘Guide Layer’ as the floor, rotate it 90 degrees on the X-axis and place it at exactly half the vertical height of your comp (if you have a 1280×720 composition, make sure that it’s Y position is 360 for example). You must respect this floor in the pre-comp or your final reflections will be wrong. This means you cannot animate any layer going below your ‘floor’ layer in the pre-comp.
    Once you have your pre-comp done place it into another composition, enable its 3D switch and enable the ‘collapse transformations’ switch. Now, duplicate the pre-comp and give it the following scale values: [100,-100,100]. This will flip all of the elements vertically around the anchor-point. Instant reflections. Reduce the opacity of the duplicate and add a blur for bonus points.
    Note that adding the blur to the duplicated pre-comp with its transformations collapsed will ‘break’ some of its 3D properties, so you’ll need to be careful with its placement in the timeline (it should probably go below the unaffected pre-comp).
    You can now animate a camera and lights in this main composition and the pre-comp (and the reflected pre-comp!) should both respond accordingly.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
    August 16, 2008 at 6:48 pm
    [Darby Edelen] “I think it’s ridiculous that they would charge $90 for that template and do the reflections incorrectly!”
    Perhaps the pricing takes into account , the inclusion of the wedding footage? 🙂
    FWIW, using AE’s Light Transformation properties is another way to get reflections.
    Cheers
    RoRK
    broadcastGEMs – templates for AE – https://www.broadcastGEMs.com
    https://www.myspace.com/RoRKrgbSpace
  • Darby Edelen
    August 17, 2008 at 10:15 pm
    [Roland R. Kahlenberg] “FWIW, using AE’s Light Transformation properties is another way to get reflections.”
    Unfortunately, light transmission will not give the ‘proper’ perspective for the reflections. In addition, light transmission only works by multiplying color values, where as a reflection will only add to the color values in the reflecting material.
    Basically, you can fake reflections in a number of ways that will read as ‘reflection,’ but there’s no perfect way to do it in AE. The technique I outlined before is the best one I’ve found personally.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
