Activity Forums Maxon Cinema 4D reflections / compositing tags / visibility issues.
  • reflections / compositing tags / visibility issues.
    Posted by Steve Davis on June 24, 2010 at 5:29 pm
    hi guys, spent the last two days on google without any luck on this so if theres anyone out there that can help it would be sooo much appreciated…
    to cut a long story short…
    i have a grey sphere on top of a plane, both have reflections set and are obviously reflecting each other, what i want is to be able to render the scene so that the floor is completely transparent and i can only see the reflections of the sphere on its surface, so just to reiterate, we start with two grey objects, a sphere and a floor plane, the final render should show a gre sphere and what appears to be a transparent reflective floor.
    so i know this can be done with object buffers but im so sure ive done this before…
    any ideas?
    regards
    james
    Steve Davis replied 16 years, 3 months ago 2 Members · 2 Replies
  • Randy Johnson
    June 25, 2010 at 8:03 am
    You can put a composite tag on the floor plane and UNcheck “seen by camera”
    /Randy
  • Steve Davis
    June 25, 2010 at 2:53 pm
    hi, thanks for your response, yes, ive tried that but my problem is, i want the floor to be transparent and only show the reflections, not its actual color, but if i turn the transparency down, the reflection disappears. i just want a clean reflection pass with an alpha, if i use multipass and select reflection, its not a clean matte, it looks pretty useless.
