Activity Forums Zaxwerks Reflection Size
  • Reflection Size
    Posted by Lee Schneider on December 15, 2009 at 6:22 pm
    My reflection is not as wide as the video footage. I’m working in an HDV project in AE but the reflection looks like it’s square pixels instead of the 1.33 of HDV. Any suggestions on what I may be doing wrong & how I can get the reflected video clip the same width as the main video?
    Lee
    Lee Schneider replied 16 years, 9 months ago 2 Members · 2 Replies
  • Edward Wu
    December 15, 2009 at 8:15 pm
    Hi Lee,
    Check the Solid that you’ve applied Reflector to. Make sure that the Solid is using the same 1.33 HDV settings as your Comp settings.
    If you’re still having issues, you can try sending the file to me at ed@zaxwerks.com and I’ll take a look at your project setup and what you may be running into.
    Best,
    Edward
  • Lee Schneider
    December 15, 2009 at 10:01 pm
    Ed, Thats what I thought of after I sent the post, but haven’t had a chance to check it out. The footage is 1.33, but the solid is a background image that I’m sure is square pixels, so that may be it. Thank you very much for the reply. Lee
