Activity › Forums › Boris FX › Reflection Effect
  • Reflection Effect
    Posted by L david Mccollum on November 20, 2009 at 3:09 pm
    What is the easiest way to do the “reflection look” of an image or logo on a background, similar to what a lot of commercials are doing now.
    L. David
    Peter Mcauley replied 16 years, 10 months ago 2 Members · 1 Reply
  • Peter Mcauley
    November 20, 2009 at 5:26 pm
    Well that depends … what host are you using? If you are using FCP then you can use the Boris Continuum Shaders to automate the process. Here’s a link to the BFX web site where you can download a trial version of BCC 6 FxPlug, in case you don’t already have that.
    https://www.borisfx.com/final_cut_pro/bccfxplug/new_filters.php#shaders
    The BCS shaders are listed at the bottom of the page and the filter that generates this effect is called 3D Perspective.
    Cheers,
    Peter.
