Activity Forums Adobe InDesign reflecting text/objects
  • reflecting text/objects
    Posted by 12thmonkey on April 27, 2006 at 6:48 pm
    i have created some rather complex type containers in indesign, and need to reflect them across their vertical axis. Is there a way that i can do this without also reflecting the type they contain? Or, can i reflect both, and then reflect the type back so it is right-reading? Any thoughts?
    Thanks in advance!
    Don’t sweat the petty things
    Mike Gondek replied 20 years, 1 month ago 3 Members · 3 Replies
  • Ron Lindeboom
    May 2, 2006 at 9:31 pm
    Is it possible to see an example of what you are trying/want to do?
    Can you send a copy of that page of your project so that I can see it?
    I think I know what you are trying to do but am still not 100% sure.
    Best regards,
    Ron Lindeboom
    ron@creativecow.net
  • 12thmonkey Create COW Profile Image
    12thmonkey
    May 2, 2006 at 9:37 pm
    ron-
    Thanks for the response. i actually already worked around it. i couldn’t figure out how to do what i wanted, so i just recreated the type container as a shape, reflected that, then turned it into a type container. Took longer, since i had to do it a bunch of times
  • Mike Gondek
    July 11, 2006 at 7:46 pm
    You would have to convert the text to outlines, then use the flip horizontal command in the transform palette flyout menu.
    You can try fooling around with anchored objects, but I could not find anythnig there and converting to outlines seems to be the best solution(though I usually try to keep things editable whenever possible).
