Activity Forums Adobe Premiere Pro Reflecting jpegs in PPRO
  • Reflecting jpegs in PPRO
    Posted by Bob Kiger on March 19, 2006 at 12:47 pm
    I just shot a nice “intervalometer” sequence with my webcam. To get it mounted correctly I twisted the camera 180 degrees but forgot to flip the picture horizontally so everything is left for right.
    I can import the stills (jpegs) into PPRO 2.0 but can’t seem to get them to flip. Can anybody give a pointer?
    Bob Kiger author of “videography” word
    http://www.videographyblog.com
    Roland replied 20 years, 5 months ago 4 Members · 5 Replies
  • Lloyd Coleman
    March 19, 2006 at 5:27 pm
    Under ‘Video Effects’ choose the ‘Transform’ folder and then the ‘Horizontal Flip’ effect.
  • Aanarav Sareen
    March 20, 2006 at 3:42 am
    And don’t forget to reduce the opacity. Gives a much better reflection.
  • Bob Kiger
    March 20, 2006 at 5:22 am
    When I select a clip on the time line or in the Preview Monitor and go to video effects tab, there is no “Transform” folder only Motion & Opacity. When I open Motion there is no transform ??
  • Lloyd Coleman
    March 20, 2006 at 6:53 am
    You are looking in the Effect Controls tab, which shows the effects applied to the clip you have selected. There is another tab called the Effects tab that has folders with all the available effects in them. You will find the effect you are looking for there in the Video Effects folder. When you have found it you can drag the effect to the clip itself or to the Effect Control folder and it will apply the filter to the selected clip.
  • Roland
    March 22, 2006 at 5:01 am
    Aanarav,
    How much do you lower the opacity on the jpegs to give them a better “reflction’?
