Activity Forums RE:Vision Effects Re:Fill Noob
  • Re:Fill Noob
    Posted by Ivan Garcia on July 11, 2008 at 2:41 pm
    Hi, i’m trying to use Re:Fill in AE to remove a vertical scratch. I’ve read the manual, but I don’t get it, I don’t know how to use the plug-in, anyone can help?
    Thanx in advance
    Ivan
    Pierre Jasmin replied 18 years, 2 months ago 2 Members · 3 Replies
  • Pierre Jasmin
    July 11, 2008 at 6:56 pm
    You need to provide a matte of where the problem area is (if you burn the hole in alpha channel, zero alpha is hole)
    eg:
    1) draw a mask 4 points rectangle that covers the bad area
    2) set Mask to Subtract
    3) set (HOLES)-White ON (check box)
    4) set process mode to Filled
    5) set Method to Blended
    Pierre
  • Ivan Garcia
    July 14, 2008 at 2:33 pm
    Thank you very much Pierre.
    The effect i get is very blurry, any tip or trick?
    Ivan
  • Pierre Jasmin
    July 14, 2008 at 6:28 pm
    It’s meant for small holes
    If there is camera movement or rig movement sometimes you want the Process Mode to be Filled Hole Only and you add some color noise a bit and composite back over original.
    If you have 5 frames with the matte you can send to techsupport@revisionfx.com for visual inspection as I possibly imagine something else then what you have as a problem.
    Pierre
