Activity › Forums › Adobe After Effects Expressions › Referencing the expression of another layer
  • Referencing the expression of another layer
    Posted by Ben Frank on November 4, 2009 at 5:57 pm
    So i have a somewhat lengthy expression that will be applied to all transform properties of all layers in a project. i would like to be able to easily update this expression and have that update ripple through all elements using it. my question is: is there a way to dynamically copy the expression of another layer? does the expression field itself have a name that i can use to copy it?
    i want to do something like this:
    thisComp.layer("layer_name").transform.position.expression;
    where “expression” at the end is whatever the name of the expression field is. any help would be greatly appreciated.
    ben
    Check out my food blog: https://iAteThat.com
    benfRank
    art direction / broadcast, print & web design / photography
    WEB: http://www.behance.net/benfrank/Frame
    WEB: http://www.benfrankdesign.com
    WEB: http://www.benfrankphotography.com
    Eric Sanderson replied 16 years, 11 months ago 3 Members · 2 Replies
  • Xinlai Ni
    November 4, 2009 at 6:33 pm
    Unfortunately no, you have’ to manually update it one by one every time you change your expression.
    But a simple script may do what you want.
    Xinlai Ni
    Software Engineer, Google Inc.
  • Eric Sanderson
    November 4, 2009 at 7:46 pm
    Dont know of a way to auto update it but the is a “copy expression only” option in edit that should make what your trying to do pretty painless.
