Activity Forums Adobe After Effects Expressions Referencing function in an external file
  • Referencing function in an external file
    Posted by Mark Chadwick on March 19, 2015 at 9:44 pm
    I’m a new user of After Effects. I created an expression calling a function in its own file so I could easily reuse it. I want to store the script relative to the project. I used the following expression to call the function.
    This approach generally works, but the directory seems to be referenced from wherever AE is invoked.
    Is there a more conventional way to perform this?
    If this is the right approach, is there a way to set a path reference relative to the project directory?
    $.evalFile("./scripts/overshoot.jsx");
    thisProperty.value = overshoot(thisProperty, 5, 12);
    Dan Ebberts
    replied 11 years, 6 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    March 19, 2015 at 11:56 pm
    As far as I know, expressions don’t have access to the path info you want. Scripting does, and a script could leave bread crumbs behind for the expression to use, but you’d have to run the script when you load the project.
