Activity › Forums › DaVinci Resolve › Reference monitor in Davinci
Posted by Josh Phoenix on April 2, 2012 at 12:58 amI don’t have an expensive reference monitor yet but I would like to see my grades in full screen on my second monitor. I tried a bunch of different menus and right clicks with no solution.
Michael Stirling replied 14 years, 5 months ago 7 Members · 8 Replies -
Eric Santiago
April 2, 2012 at 4:19 amI dont think there is a way with Resolve.
Only the Scopes can be moved to a second monitor.
Maybe in future upgrades. -
John Michaels
April 2, 2012 at 4:29 amYou can get a Blackmagic Intensity Pro card for under $200 USD (among other options) to send the video to the second monitor. Otherwise, Resolve does not seem up support multiple monitors at this point.
Jonathon Lee
April 2, 2012 at 4:56 amEric is correct. There is not currently a “dual graphics” monitor mode with Resolve.
You need to use a Decklink card that supports the video format you are using. Best is the Decklink HD Extreme 3D, but you can use many of the other Decklink cards as well. For REC709 in a non-RGB mode there are some cheaper ways to go if you need to “make it work”.
You could use an Intensity Pro with a Panasonic plasma. That may be the cheapest semi-ok way to go.
Gabriele Turchi
April 2, 2012 at 7:01 amHaving the possibility to Move the GUI in the second monitor (mainly for node tree and still store , or shots thumbnails etc… is one of my big hope for new release …)
as far as image , you want it to be out of a BMD card to avid OS icc color manipulation ..
Davinci Resolve Control Surface
MacPro
Cubix desktop 4
2 Red Rockets
GTX470+GTX470+GTX285
24GB RAM
HP Dreamcolor
Panasonic 58PF Plasma -
Esteban Aguilera
April 2, 2012 at 8:05 pmjust say to those who recommend the intensity pro, I would like to comment as they would do the calibration of the monitor.
thank you very much
Di Davinci Resolve Colorist
Michael Stirling
April 3, 2012 at 11:54 ampresumably you would calibrate a monitor run from the intensity pro over HDMI the same way as any other non broadcast monitor – with a probe and some overly expensive calibration software to profile and create a LUT
~M
Esteban Aguilera
April 5, 2012 at 2:48 pmCan you explain a bit more the process, please ?
Michael Stirling
April 5, 2012 at 3:57 pmFirst I don’t own an intensity pro and haven’t done this
but if you wanted to use a screen like a panasonic vt30 plasma say over hdmi then you would need to use a probe like the xrite i1 in conjunction with some profiling and calibration software to either get the monitor displaying accurate rec709 (presumably) or close to rec709 with a display LUT in DaVinci getting it bang on.
Software that is out there are things like Cine-tal Cinespace (recently bought by THX) or LightSpace CMS.
Unfortunately they will cost you more than the 50″ plasma. If you really want to get into it I’d suggest https://www.avsforum.com/is a good place. Though it’s mainly about home theatre set ups there is some very knowledgable people on there.M
