Activity Forums Adobe After Effects Reference Monitor for Color Grading
  • Reference Monitor for Color Grading
    Posted by Enginn Heima on September 16, 2008 at 9:22 am
    I’m struggling finding myself a decent monitoring. I’m doing more and more color grading and after effect work and so far I’m using my old CRT Sony Trinitron 19″ monitor for referencing. I want to spend few bucks on a new monitor but I’m getting lost. Do I get a flatscreen computer monitor or a flatscreen TV monitor or a better CRT monitor.
    So far, what I’ve found, and I find the most intriguing for the money I can spend (max 1000euros) is the Lacie 324 ( https://www.lacie.com/products/product.htm?pid=11034 ) but it has NTSC gamut!? Whereas I’m in PAL land and the projects I do are either standard DV def or HD 720p or 1080i. It’s also on the expensive side compared to what I can afford.
    I was also thinking about getting myself the Blackmagic Intensity Pro (https://www.dv.com/reviews/reviews_item.php?articleId=196603506 ) to add a HDMI output.
    Well, if anyone can help me shed a little light, it would be much appreciated.
    Best regards.
    Enginn Heima replied 17 years, 11 months ago 2 Members · 2 Replies
  • Grant Lovering
    September 17, 2008 at 2:06 am
    Definitely something that will take a video source (ideally HD-SDI) so you are viewing a broadcast reference. Id recommend looking at the JVC DTV series. We recently road tested a whole heap and found this to be the best. One I would have liked to have tested that we couldn’t get down in Australia was the eCinema, it gets good wraps. Found the TV logic had pretty bad off-axis viewing angle with massive shifts and looked pretty average too. The Sony range is pretty overpriced and underachieves quality wise.
    https://pro.jvc.com/prof/attributes/category.jsp?productId=PRO2.1
    Hope this helps.
  • Enginn Heima
    September 18, 2008 at 9:38 am
    Thanks for the post.
