Activity Forums Adobe After Effects Expressions Reference layer by index, defined by slider control
  • Reference layer by index, defined by slider control
    Posted by Noel Powell on November 3, 2014 at 5:26 pm
    I was wondering if anyone can think of a workaround for this apparent limitation in referencing layers. I am trying to reference a layer by its index, rather than its name. That’s easy but the error comes because I need the index layer to be defined by the user (via slider control). I have something like this:
    layerIndex = effect(“Slider Control Name”)(“Slider”);
    comp(“Comp Name”).layer(layerIndex).transform.opacity
    the error says “index out of range”. Any ideas? Thank you.
    After Effects templates – lens flares, light leaks, old film effects, digital glitches, VHS glitches, and more: https://CreationEffects.com
    Noel Powell replied 11 years, 10 months ago 2 Members · 3 Replies
  • Noel Powell
    November 3, 2014 at 5:33 pm
    NVM, I just figured it out. I should have thought of this before. For anyone else who might want to do this – you can have the user define the layer using the Layer Control, rather than a Slider Control. Then in your expression, just pick whip the Layer Control.
  • Kevin Camp
    November 3, 2014 at 9:02 pm
    a layer control is definitely a better way to go, but you could use a slider to drive index, you’d just need to add a little more code to avoid the error.
    the first error you had was likely due to a number (like 0) that did not equate to a valid layer index. you could use an if statement like this to avoid the error:
    if (layerIndex > 0 && layerIndex <= comp("Comp Name").numLayers)
    you would also want to limit layerIndex to integers/whole numbers with a fuction like Math.round() or Math.floor(), etc…
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Noel Powell
    November 3, 2014 at 9:13 pm
    Thanks for the response, Kevin. I actually had the slider control set to 9, and there was indeed a layer # 9. I would try the expression with the actual number in there, and it would work fine. Then I’d highlight the “9” and pick-whip the slider control, which was set to “9”, and it would return the error. So there must have been something else going on.
    Anyway, the Layer Control works great.
