Activity Forums Broadcasting Reference for UVW 1800
  • Reference for UVW 1800
    Posted by Tim Taylor on May 31, 2007 at 8:44 pm
    I’m pretty sure this is a VERY basic question, but it’s one I’ve been ignoring for over 10 years.
    What’s the best* way to sync up my UVW 1800 BetaCam SP deck with my NLE (FCP5)?
    *By BEST, I mean “best value” or most “cost effective” while maintaining a solid clean recording?
    When I loop the composite out to the ref video, I get the “NON-STANDARD REF” alarm. I just bought a black generator, hoping to solve the issue once-and-for-all, but it doesn’t seem to do anything. I still get a “NO REF” alarm.
    While it’d be interesting to understand the purpose and use of reference video, I’m afraid if I haven’t figured it out by now, I may never “get it.” I’ll settle for whatever works.
    TimTaylor, Editor
    RESolution Media Services, LLC
    Lance Gropper replied 19 years, 3 months ago 4 Members · 5 Replies
  • Rhewitt
    June 1, 2007 at 5:14 am
    The output of the black generator needs to go to the Ref I/P on the VTR.
    The only real benefit of having a sync source is if you use RS422 to control the deck. Under RS422 the time code of the VTR is fed to the NLE.
    Once correctly sync’d you can insert edit on the VTR under control of the NLE app.
  • Rhewitt
    June 1, 2007 at 5:16 am
    Ooops, forgot to mention that using an external reference forces the VTR playback head/drum motor to lock to the ref signal and ensuring greater stability of playback.
  • Tim Taylor
    June 1, 2007 at 11:06 am
    UPDATE: I now believe that my black generator isn’t putting out any signal at all.
    That would explain the “NO REF” alarm!
    Any suggestions on how I can check the existance of a black video signal w/o a scope?
    Thanks for the replies! Make it sound like it’s no mystery at all!
  • Charley King
    June 1, 2007 at 2:10 pm
    Try digitizing a signal direct from the BB Generator. See if it comes into your FCP with burst and clean black.
    Charlie
    ProductionKing Video Services
    Unmarked Door Productions
    Flamingo Las Vegas Hotel
    Las Vegas, Nevada
  • Lance Gropper
    June 18, 2007 at 4:14 pm
    Hello Tim:
    {You are not hearing this from me — it’s your imagination}. In my old dealer days, you had to loop the Composite video IN – not out — to the REF IN to get rid of the error. When you do this, use a very short cable — something like 6″ if you can get it.
    Lance Gropper
    Ciprico
